Hallo there!
I am working in a small recently established computer repair shop and at times we have difficulties formatting some particular storage devices. When this happens, it affects our reputation so much yet this is what we are out build. I was wondering if there is a power full formatting tool that is able to format all drives and completely clean all the sectors? Thanks in advance.
What powerful formatting tool can format all disks?
Hi Grant,
Here are the free tools that you can make use of in your job as a computer technician.
Kill Disk ​DOS+Windows Suite v.7.5  – this program securely erases data and comes with a collection of powerful disk and security utilities. It is easy to use and an instruction to create a Bootable USB disk is provided in the website's page.
Even if it is a Free program, there are several good features which is very useful. Check it here.
GParted – this is a partition editor for graphically managing your disk partitions. You can resize, copy and move partitions with no data loss which also allow you to do the following:
Grow or Shrink your C: drive
Create space for the new Operating System
Attempt data rescue from lost partitions
For more detailed information of GParted about its system requirement and additional features, you can check it here.
I hope this solution have given you a good information.
Hi GrantÂ
There is a program called HDD Low level Hard disk drive format Its a really easy and efficient program to format any hard disk.Â
The great thing in this program is its low level formatting and that means it leaves every sector with zero byte space which is great thing for maintenance.
The fact is it reinitialize the hard disk to its factory settings. You download it from Here.
Partition Magic is another one i personally use its really efficient specially its Dos mode.Â
And you can do many great things like Check disk , Scanning for bad sectors and I think that suits you more because of its features and its availability for Mac and Windows.Â
You can download it from Here.
