The error message below is oftentimes encountered while trying to connect.
What precisely does this error really suggest?
I understand the product in query includes the Altiris Agent SetUp, which is operating properly as confirmed by successful application delivery jobs currently taking place on the targeted program.
RAAD
Altiris Agent not installed: Access Denied
Hey Jughead Mason!
If you are getting this message which indicates that you have not installed Altiris Agent, then there must be some problem with your registry. Most of the times our registry of windows becomes damaged or broken, that is why we have to face such errors, even we have the program installed on our computer.
Anyways do not worry about this error message; What you have to do is just to install the registry cleaner program. I would like to recommend you tune-up utilities. This software will not only fix your broken registry but will also optimize the speed of your computer.
Once install it, run the software and after it finished fixing the broken registry, restart your computer.
Thanks
