I use a very simple CDMA Motorola handset. Model No: W150i. when some one call me, sometime there is no name or number is shown on display.but ringing and lighting is OK. What is the problem of my mobile? and what is the solution of it?
What is the problem of my mobile’s display?
Yes it really is annoying to have a call from someone that say no number or it doesn't show any number at all.
You don't have any problem with your mobile phone but rather what you are experiencing is that someone is calling you from a different country.
Most probably it is someone you know that lives overseas. So don't worry to much and just answer the call to know who is it. It might be an emergency call or just a plain simple call to have a little talk with you from relative or friends that miss you so much.
Hello dear, whatever problem you mentioned here is not a problem of your device. I mean to say that this problem is not because of the problem of cell phone or if you think that there are some faults in your Motorola set then you are totally wrong.
Actually the problem is that there are some call centers working around an also there are some of the technical services from communication networks and those agencies can call anonymously without having name.
So the best solution is that never pick up that call and reject that call manually.
