What is the problem with my No Thirst Software LLC?
Good day to all!
I am having problems with No Thirst software LLC for my personal finance. I am using Mac OS for it.
At first, it was working well until an error appears that it is not installed correctly. Can you tell me what the problem is. I am guessing that some tool is missing.
Thank you!
Answered By 0 points N/A #164867
There could be any one problem among three.
1. Some file might get deleted.
2. Might be virus has effected your application.
3. Antivirus is blocking the some files of that application.
As you are saying that first it was working good. So check out your antivirus database whether it is blocking the files related to your application.
If you are still facing this problem uninstall the application and install it.
Hope you got some need full from the post.
Hock Clotildec.
