What is the problem with my Pen drive?
My Pen drive is a 2 GB drive, but when I save any file up to 900 MB, then it shows me a message, "I have no enough Memory".
Why does it give me that message ?
Hello!
Seems like it is a virus problem. So try scanning your pen drive. If no virus found their, there could be hidden files and folders so copy all the files from your pen drive and save it in your PC or laptop. Then format your pen-drive.
Right click the pen-drive and click on properties.
If it shows 2 GB or little less than your problem is fixed. if not then your pen drive must have some kind of virtual software which is showing 2 GB but actually is a lesser one.
Which could not be fixed.
Click on the properties of the device and check the actual storage space. Also check how many memory is used and which is not in use. After this take all data out from your device and format it using a FAT 32 format. Then you can convert it to NTFS also.
After you done check the storage space again and make sure that your device is ok. Next thing is to run a scan on your drive go to CMD by going to START and then RUN here type CMD and click ok after you are done now enter the command to check your drive type chkdsk D: Where D is the drive letter you want to check.
When done see the result.
If the drive is ok then be happy or else run a scan on your drive and make it error free.
