What is the process to create a windows shortcut?
You could easily create a shortcut to program in Windows.
Please find the following for your reference.
a. Open directory/folder where is the program that you want to create a shortcut.
b. Right-click the program. Choose Create Shortcut.
c. The shortcut is then created and the name will be ‘Shortcut to ‘program’’. You could also rename this shortcut by using the right-click.
d. After you complete the above, you can cut, copy, paste or move the shortcut to anywhere to run the program.
To create a short cut to an application go to the application folder. To locate your application folder if you have already installed it, go to main C drive > open program > open your application folder. Right click on the application.exe then click on send to desktop/create short cut to desktop.
Usually every new installation has options for to chose to have a short cut or not on your desktop. Kind regards. Richard
Hello Tomwelton, To create a shortcut for a file in windows, it is easy. Just locate which program, document or file that you want to create its shortcut and then click on create shortcut. The shortcut will be automatically pasted on the desktop so that you can access the program, document or file easily from there. You should note that when you delete the main document or program and the shortcut remains, the shortcut will be useless. The shortcut will only work if there is its original program somewhere on the computer. Hope this helps. __ Regards Mahesh Babu
