After performing IPL, using iseries, I could alter the internet protocol address from an activated point to an inactivated form. We are about to carry out a DRP analysis and therefore I need to urgently know the process for this. I am expected to tune-set the current internet protocol address and deactivate it and then make active a DRP internet protocol address after which I am expected to effect an IPL. Sometime ago, after carrying out an IPL, the alterations made on the production and DRP internet protocol address are not carried out. I would like to know the way in which I can set it up such that the alterations made before the IPL is carried out will be achieved. Â
jhon12
What is the process for doing DRP analysis
for of all you have to select the testing methodologiesÂ
The DRP is tested to the fullest extent possible
The associated costs are not prohibitive
Service disruptions are minimal or non-existent
The tests provide a high degree of assurance in recovery capability
Evaluation of test results provides quality input to DRP maintenance
Follow these steps for testing. Analyze the test one by oneÂ
1.    The Cycle Testing Paradigm
2.    Walk Through Testing
3.    Simulation Testing
4.    Parallel testing
5.    Full-interruption testing
Just confirm that the result of your tests must meet your desired criteria
After conducting these tests you have done DRP Analysis
Hope this will help you.
