What is the process of managing sales in jira?
Hi expert,
I am facing a problem with managing sales in jira. I tried many times but failed. Please, tell me the process of managing sales in jira as easily as possible and of course step by step. I am waiting for your reply. Please, reply as soon as possible.
Thanks in advance
Best Answer by Stella T Finley
Answered By 70 points N/A #150060
For this problem you need to check out, what the Filemaker software supports features like SQL, MySQL, Oracle Server etc.
You need to properly check out what the Filemaker supports.
 Its has a robust, relational database architecture which helps you in greater scalability and higher productivity compared to Microsoft Excel or Microsoft Access.
It helps you to create database in windows, Mac, iOS and the web.
Answered By 10 points N/A #150061
JIRA is easily and efficiently for managing tasks and presentation, I give you an example like JIRA for Project management, like how use JIRA to manage internal processes purchase, marketing and other product, There are several and separated user different levels in team within the company, You can view user between switching, you can create work, tasks sales position etc. you can move the issue with respective steps, reports are pull on issues and activity. This is just an example of too many ways to use JIRA to manage your project.
Thanks,
Stella.
Answered By 65 points N/A #150062
Go to dashboard and create using whatever name. Add five gadgets: filter results, create vs resolved chart, issue statistics, road map. Think of the issues and the issues resolved. Configure this gadget. Click save and you will notice that issue resolved is noticeable. Jira components will show you if team has made an effort to really work hard. Pick a gadget and compare. Jira is very helpful with regards to target dates. If resolved issues are exceeded by unresolve issues then there is a change of target date.
