What is the process of proxy setting for nokia care suite?
I need to create a proxy setting for nokia care suite. But I don't know how to do it. So, please tell me everything successively as I can do it easily.
Thanks
Thanks
Before setup proxy settings, you need to update your Nokia Suite. If you are using latest version of the Nokia Suite. Then you can follow the instructions that I have given below.
In the Nokia Suite window, Click Menu > Options > General > Proxy.
Note: Usually Nokia Suite get the proxy settings from the windows default proxy settings.
Also you can change the Proxy settings in the Internet Option. If you want to change it in the Windows please follow the instructions.
Go to the Control Panel > Network and Internet > Internet Options.
Then you have to go to the Connections tab in the Internet Properties window.
Click LAN settings. You can see a new window appears. In the Local Area Network (LAN) Settings window, select ‘Use proxy server for your LAN’. Then click OK.
Another important thing is If there is an authentication for access your proxy, you need to set the WinHTTP proxy setting using a command prompt.
Open the command prompt and type the following code.
netsh winhttp set proxy < In this area you need to enter your proxy > “< EXCLUSION LIST > “and press Enter.
Make sure you have to enter this code after logging to the Administrator account.
Hope this will solve your problem.
