Hi techyv,
What is the process for ps2 convert to pc online? I want to convert or transfer those ps2 files such as movies, games and etc. In to my computer via online through wireless internet connection. But how will I set it up?
Hoping for your help.
I Dont think it would be possible to transfer the data between ps2 and pc wirelessly . However if you want to transfer data then you can make use of the provided SD Card. Store the data from ps2 on the SD card and then copy paste on the computer using a simple card reader.
Also to open the ps2 data you would need two software's Ps2 save builder( to run a saved game ) and mymc.
Thanks!
