anonymous
7060 points
Posted on - 10/02/2011
When I cannot reach my destination server and want to remote login from a far distance then what should I do?
Is proxy server an option that performs well in this matter or what processes can I use to login in my web page using a server.
kewinson
What process (Server) should I use?
Hi
I think I can help you.
So you want to login to the destination server remotely.
As per my knowledge there are some software that can help you. If you using Windows environment or Linux environment there are some software that can help you.
I found an article that has lot of details that are suitable for almost all operating environments.
This is the link Here.
It is easy if you using a free and open source operating system, because all the software that is needed are free and available on the Internet.
I hope this will help
Thank you.
