samwatson
10 points
Posted on - 03/06/2012
There is no multi-band equalizer for Windows 7, but we can change the media player setting to change the equalizer. The downside is it’s useless for online material. I can’t find any program that would allow me to do this.
Do you know of any? Please share it with me.
Thank you!
What program has multi-band equalizer for online material?
Hello Samwatson.
What motherboard are you using? The only way for you to get the desired audio adjustment not just for online material but for all audio outputted through your PC is to make use of the graphic equalizer that comes with your audio chip.
Most motherboards and notebooks nowadays use onboard sound made by Realtek. Back in 2009 when Windows Vista and Windows 7 were still new, Realtek removed the graphic equalizer settings from its audio manager software. But now that Windows Vista and Windows 7 have hit the mainstream, the graphic equalizer is back. To access it, simply double-click the system tray icon of your Realtek Audio Manager and follow this screenshot:
Hope this helps!
