elsietbrown
20 points
Posted on - 06/14/2012
 I need information regarding my web site.  What kind of program do I need to embed a search engine for my website? I want it for five different boxes like, for an address but I want only to pull up that address. Do I need a php or sql?Â
What program is needed for embedding a search engine?
There are search engine that can be installed in your computer without installing any program. Like the zoom search engine. It is easy to install to your computer and can search anything too its also accurate. This is the Version 6. This a free search engine, there is no scripting, no problem with the database. In this engine you don’t have also external web service that is required, and most of all can be configured. It can search on html, php, asp, cf, pdf, doc,ppt, xls, swf, jpg, gif . This can runs in all the webs and even in the hosting plans. So in this engine you have an easy life and free of the drama of installing and downloading big bytes of other requirements in order to install a search engine.Â
