What is the proper PDF 2 excel convertor
I have about 25 pages of data files as PDF. Now I needed to edit them in Excel. So, I want to convert those PDF files to Excel Sheet. Can you send me a proper PDF 2 Excel Converter?
I understand you are looking for a "PDF-to-EXCEL" converter. There are many software/freeware available online for converting a PDF file to Excel. Here are a few links you might want to go through; you will surely find a good PDF to Excel Converter:
1. https://www.pdftoexcelonline.com/ – It is an online converter, you can upload all your files here (one-by-one) and you will get excel files on your email. This site asks you for 3 simple steps: upload your PDF file, give your email and clear a captcha. If the requirement is for a short period of time, then you can also download their free converter.
2. http://download.cnet.com/PDF-to-Excel/3000-2079_4-10464282.html – Here you have to download the software, of course it’s a freeware, but it might also install a CNET download toolbar on your computer, which you wouldn't want otherwise. If you have to download freeware frequent this site might be a good option.
3. http://www.pdfexcelconverter.com/– One more good converter & its free! Provides good quality excel sheet.
I suggest you go with the first option if this is a onetime matter. You can provide an email which you don't use frequently and check your SPAM folder in case the mail is directed there.
Hope this helps!
Notifications
