What is the purpose of the disk clean-up in windows 7?
Disk Cleanup removes unneeded files, such as files that you downloaded to install programs, temporary Internet files, files in the Recycle Bin, offline Web pages, hibernation files, setup log files, temporary files, and thumbnails.
The easiest way to access the tool is to type disk cleanup in the Start search box.
Thank You,
John Major.
Hello Michal,
Thanks for sharing your problem.
Dear disk clean up is a very useful and beneficial tool for windows 7 or any.
When we run this tool, it cleans all temporary files, registry entries etc.
It saves a lot of gigabytes of disk space.
And makes pc better in performance.
And sometimes when we delete some files, those files go into recycle bin. This disk clean up tools remove all those files too from recycle bin to save the disk space.
I hope it will help you to understand your question.
Thanks
