What Is QAD? Building ERP Cloud Software For You
What is QAD? What is the aim of the company? What is the procedure to report an incident to the QAD Customer Support and what factors influence the resolution of the incident reported?
Answered By 20 points N/A #166071
The answer to your first question what is QAD is that it is a company which provides ERP software to some manufacturing companies. QAD’s cloud computing model is known as QAD Cloud ERP. At present, 5300 manufacturing sites in more than 95 countries are using QAD’s software. QAD was started by Pamela Lopker in 1979. The main aim of QAD is to provide flexibility to your business, minimize the risk while providing control, simplify the ERP software, be ready for whatever is in store for a solution and make ERP solution accessible to wherever your business goes.
To report an incident first, prepare an incident comprising of your basic contact information such as customer Id, type of hardware and OS running the software, QAD software version number currently being used and telephone, fax, email address. Also include the problem- related information consisting of the error message being displayed, symptoms of the problem, since how long have you been facing it. Screenshots are advisable to get a clear picture of the problem. After the incident is prepared, report the issue to your respective QAD service provider depending on the service area.
The resolution depends on how severe the problem is, the accuracy of the report submitted, how easily and fast can it be resolved, the complexity of the problem, and also if the problem can be solved by QAD itself or any third party needs to be involved.
