What is Quickpull in Blackberry?
I always read some tweets from my friends that they are "quick pulling." What is this Quick pull thing in Blackberry phones? I'm planning to buy my own blackberry that's why I also want to know this.
Quick pull is an app which allows users of blackberry to do a battery pull or a hard reset of the mobile. It is safe to download and install this application on your mobile phone.
There is a free version as well as premium version which will allow you to reboot your phone at a free cost and as well as at paid cost. Just kidding.
You can download this application in your blackberry and run it occasionally when you feel your mobile is not working properly as expected. This will do a hard reboot of the phone at a time. It is advisable to do it regularly I mean every day to keep your phone in proper manner.
Dear,
Quickpull is a 3rd party apps that allows a battery pull or reboot of your blackberry. There are two versions, free and premium. From my experience it is completely safe. This is required to free up memory and keep your phone running well.
Thank you.
Right, QuickPull is another piece of application for the BlackBerry Smartphone. It allows you to perform a soft reset of your phone without manually turning it off and physically removing the battery from the handset. With this application, performing a soft reset of your phone is done with just a few clicks. Aside from soft resetting your handset, it also keeps an eye on your memory.
If the memory of your phone falls below a pre-determined threshold, which is measured in MB, the application will trigger your BlackBerry to alert you and prompts you if you want to reboot. So, in general, QuickPull’s main function is to optimize your usage by freeing up memory. QuickPull comes in two varieties: QuickPull Pro and the free version.
Both versions were developed by Steelthorn Software Ltd. and they support BlackBerry OS 4.5 and higher. If you want to try it on your BlackBerry Smartphone, download the latest QuickPull 5. Take note: before upgrading your application, uninstall first the old version and then install the latest version.
