elsietbrown
20 points
Posted on - 05/10/2013
I use Qvod Player Version 5.4.11 for playing my multimedia files and streaming content. I am now on a Windows 8 OS. What is the Qvod Player last version and could this be a compatibility issue? Thanks in advance.
What is the Qvod Player last version?
Hello Elsiet,
Qvod Player latest version is the Qvod Player 5.8.130 with QVOD Technology as its publisher. This update was released on the April 19, 2013.
Its system requirement: Windows 7, Vista, 2003, XP
The above operating system requirement which excludes Windows 8 (your current Operating System).
Yes, would rise the compatibility issue, i.e. Windows 8 OS is incompatible.
Link: Qvod Player 5.8.130
Your best alternative is to move to your second best multimedia player (if any).
A change might excite so go on and try.
There is Qvod player 5.6.124 from Task Technology Company Ltd which was released on 1st of November 2009 .so far this is the latest version Ovod play 5.6.124 with the size of 540 kb I have used and I think it will be useful for you. It has various features that enable you use and it’s also used online
