Xming is a X windows leading server for Microsoft XP vista and window 7. It is simple and easy to install because it is standalone native Microsoft windows. My question is I am searching about reading xming iPad, is there any available xming application for iPad?or if don't have Is xming application will work if I install it on my iPad?
What is Reading xming iPad?
Unfortunately, Xming app does not available for IPAD or MAC. Xming only compatible for windows operating system. It will be waste of time if installed that software in your Apple's IPAD. Everybody knows the apple and windows rivalry. It is better to look for other alternatives. Check in apple's app store. You will get something good, If not as good a windows Xming. One other thing that you can do is trying Windows 8 Surface tablet.
You can share and edit xmind file on iPad with the ''iThoughts HD v2.2'' application. It is very easy to use. It gives you the opportunity to upload or download maps. To upload a map to the xmind.net, you have to open a map with iThoughts, click the ''transfer'' and then ''Export option''. Then you have to enable the ''xmind'' and after that click the ''Send to Xmind.net''.
