anonymous
7060 points
Posted on - 08/29/2012
I badly need somebody who can tell me of what is really going on with my MS Office. When I try to open an application in MS Office there would always an error that would come out.
What should I do so that I can get rid of it? And this is not only with one application I use but also along with many others. What does this error message exactly means? Can this still be removed?
Microsoft Office Activation Wizard
Microsoft Office Professional Plus 2010
Active Wizard
This copy of Microsoft Office is not activated.
This copy of Microsoft Office is designed for corporate or institutional customers. Connect your
computer to your corporate network to complete activation. Your system administrator can help.
Learn more about how to activate this Office product
If this software was not purchased for corporate or institutional use, it may be counterfeit. Using
counterfeit software exposes your computer and data to increased security risks, including viruses.
Learn how to purchase genuine Microsoft Office products
        Change Product Key
Error Code: 0xC004F074Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Privacy Statement
Help        Close
I would gladly appreciate your help.
What is really going on with my MS Office
Hello.
The ms office package you installed is designed for corporate or institutional customers. That means this package is only for limited customers
The reason for your error message is that you did not activate your ms office online via internet since this is a limited edition.
Try activating online with your product key or else buy a new product key.
Thank you.
This copy of MS office is for institutional and corporate customers.
You can reinstall as a corporate or institutional customer, because your product key is valid for institutional and corporate customer.
Otherwise you can purchase a new product key for individual use.
Thanks!
Hi,Â
     There's only one way for you not to encounter that error. You need to purchase a new cd for your microsoft word. That error cannot be removed unless you have a product key for that application you installed. Though you can still use the same cd or the same file you downloaded to have microsoft office but you will still encounter the same error over and over again.
Best Regards,
Jerameel Cyrus Tubon
That is actually not an error but an activation notice which usually appears when the product is not yet activated. If you receive this message every time you run a Microsoft Office application like Microsoft Office Word, it means your Microsoft Office suite or the entire Microsoft Office package is not yet activated.
I’m not sure if you can continue using the application even if it is not activated but if you can no longer use it then that means you have to activate the product or uninstall it. This normally happens when you install a trial version and the trial period has expired.
To activate the product or Microsoft Office, you need to buy a license for the product to continue using it. If you can’t activate it, just uninstall it from your computer.
