Hello guys, I need your help. I need realplayer uninstall from command prompt. Do not ask me why. Is there way to do this? Can anyone help me with the details instruction how I can do this from command prompt? Please do not ask anymore question. Provide step-by-step tutorial.
What is the RealPlayer uninstall command line in command prompt?
Greetings!
To uninstall realplayer using command prompt you should find the "Uninstalling String" in the Registry Editor.
To find it here is how you do it.
1. Goto Start Menu > Run and type RegEdit > Hit Enter
2. HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrent VersionUninstallReal Player 16.0
3. Type the Uninstalling String in the command prompt. See example:
"C:Program FilesRealRealPlayerUpdater1puninst.exe"Â /s
Hit enter and a dialog box will appear for uninstalling RealPlayer. Hope this helps. Thanks.
