Shaun L Day
Posted on - 03/07/2013
While working on Microsoft InfoPath an error message occurs like the one given in the screenshot. Can anyone solve the problem please?
‘Warning
There has been an error while processing the form.
Click continue to resume filling out the form. You may want to check your form data for errors.
Click Start Over to load a new copy of the form.’
What is the reason of this Microsoft InfoPath error message?
Hi Shaun,
To solve this error follow these steps
1) Have you enabled "Full Trust" to the browser enabled Infopath form.
Infopath forms with full trust, we can't publish it directly to MOSS 2007. First we have to publish it to a file location, and then get an administrator to upload it to MOSS via central administration.
2) Add a data connection library to MOSS and saved the webservice connection to that library.Check the "Allow cross-domain data access for user form templates that use connection settings in a data connection file" in Central Administration. Now this will work for admin user if you want it to work for normal user approve the data connection file in the library.
