What is a red gate SQL dependency viewer?
Who can give me an idea or over view on what is a red gate sql dependency viewer? How it works. its purpose and relevance. I just want to know for me to be able to submit a simple report. Thank you.
Red Gate SQL Dependency Viewer is a helpful tool that lets users to discover and study database objects. This software was planned to be a device that can help you acquire a general idea of which task and assemblage are submit and from where. It has a number of tremendously helpful purposes.Â
Best regards,
Heather marie
The tool which you are referring to is SQL dependency tracker which is from red-gate. This tool is mainly used when you want some schema of the existing database need to be changed. Suppose you have a scenario where you need to change the schema of a DB without effecting other DB's. Manually we need to look into many objects and other databases how they are going to impact. In order to solve this they have come up with a tools like SQL dependency tracker which helps you in identifying the objects of that particular DB and what will be effect on that. The main intention of this tool is to list the object dependencies on the Database.
