What is the relationship between hardware and software?
Hello there
Hardware and software are like ying to the yang.
You just can’t have one without another.
You can imagine car as a computer.
Inside computer you have different kinds of hardware (hard drive, motherboard etc.), while inside car you have engine, shift and many other things. Without software you can’t’ do anything with your hardware, because software is some kind of connection between human and hardware.
For example, you’re seeing this answer in some kind of software for Internet browser. Without them, you’ll have to read this answer as a 10010011111000111, which is kind hard JSo, to finish with my example, software is a gas to the hardware (car), because you can’t run car without gas.
Hope this helps!
Hardware and software are like to the interrelated .
You just can’t run one without another. You can imagine car as a computer. Inside computer you have different kinds of hardware (DVD, Keyboard, Printer, Ram, AZP Card, hard drive, motherboard etc.) But this item not run of software.
Without software you can’t do anything with your hardware, because software is some kind of connection between human and hardware.
For example, you’re seeing this answer in some kind of software for Internet browser. Without them, you’ll have to read this answer as a Windows XP, 7, Windows media player, Office XP etc. software items.
A printer cannot work to install printer software work than proper work.
May be you understand think.
