What is required for NetApp placement requirement?
Please, some one guide about the NetApp requirement process for being students.
Which are the important concepts required to be studied?
You can start your preparation with NetApp support system. You should learn thoroughly about Operating systems and the products. You should go as deeper as you can these topics because they hire level 2 support profiles that have very good knowledge in such topics.
Moreover, you need to have good computer software concepts which will help you to go smooth inside this system. Start with OS concepts first and then, go deeper into the software and programming concepts.
Anyways, all the best .
