What is the responsibility of /etc/passwd file in RHEL system
Hi Saul,
Thank you for your previous answer, I found /etc/passwd file but I don’t understand few contents of this file,
Can you help me to figure out this please?
Hi Saul,
Hi Yorath,
Hello James,
The /etc/passwd file usually holds the essential information that is required during login, for instance the user account information.
The /etc/passwd is usually a text file, and it has got a list of the system's accounts, and for that matter it gives each account some useful information for instance the user ID, the group ID, the home directory as well as shell and so forth.
This file should be able to have general read permission as many utilities, for instance less use it to map user IDs to user names, but write access only for the super-user (root).
Hope this helps.
Carl
