What is router?How does it work?
It is one kinds of devices which connects two or more pc to establish a network or to connect with the internet. Commonly connect two or more LAN or wlan or ISP. It passes data packets. We can see that there are many types of router but main two categories one is wired router and wireless router. So we needed it to connect our computer with network of other computers. Maintaining a connection between two or more computer or to connect with the internet we need router. Without router broadband connection can only give to one computer. If we want to know more information about router we can go the following sites: https://computer.howstuffworks.com/router.htm.
Thank you. Â
Router is a device that connects you to internet using a service. You need a service provider to met these requirements. You can get a service and can use router to get your network traffic. In simple words it connects you to the whole world using a network service. It routes the data over a network and you can use it to connect two computers and then can share any data that is require to share over the network. A router is a device that works on signals and can send and receive messages or data over a network. If you need to get connected over the network or you want to share some data over network then you can use router device for this purpose. I hope it will help you a lot to understand what is router and what are its functions.
A router is a specialized computer connected to other networks. It runs a software that allows device to move data from one network to another. The primary  function of a router is connecting networks together and keeps certain kinds of broadcast traffic under control by breaking down large number of hosts into smaller networks.
Today, people are connecting to the internet,it is a very large network so you need a router to connect your  network to internet. It shares internet connections to other computers, laptops, or devices with network capabilities. It does not provide internet but distributes your broadband connections to other devices.
