I have always had problems with driver updates that I end up with a lot of little red icons on my device manager. Please tell me what is the best automatic driver update program to help me with this issue. I know there are several out there. I just want to make sure that it will be worth paying for. Please leave comments about the program too. Thanks
What’s the best automatic driver update program
Hello Eckel,
If you are the user of Microsoft Windows 7 or later versions then the best Automatic Driver Update is the Microsoft’s built-in utility named as Windows Update. All that you have to do is just to turn on your Automatic Windows Update and it will download all of your drivers that might have been creating stress for your computer. Once you restart your PC after necessary updates it will automatically installs the new updated drivers.
Driver Reviver could be your best bet when it comes to a driver-updating application. This software solves your problem of manual or incomplete updates of your drivers because what it does is it scans all of your computer's hardware and identifies the current driver installed, and determines if it is the most updated version. Once the required updated are identified, Driver Reviver allows you to easily download and install them from one central location.
Driver Reviver also ensures that your computer is at its optimum performance, as well as its components and applications.
