olivia.bha
70 points
Posted on - 06/06/2012
I wanted to buy a new Bluetooth headset to pair with my mobile phone and I just could not figure out which one to buy exactly. Plantronics Voyager PRO HD appears to be giving out better feedbacks. However, I would like to know if it is designed to only work with a specific device.Â
I was pairing issues with an aging one I have and I am trying to avoid a repeat of the same issue.
What’s the best bluetooth headset in the market today?
Jawbone Icon Bluetooth headset.
There are various Bluetooth headsets available in the market these days. One of it is the Jawbone Icon Bluetooth Headset. This is one of the most pricey available on the market. It cost $79.99 and it is awarded as one of the Top 10 Reviews Silver Award.
Jawbone Icon Bluetooth Headset has a selection of distinct fashions. It touches your cheek with vibrations placed on your jaws to block other noise.
It also has an outstanding sound quality so even if you are in a congested or in a windy area, you can perfectly make calls without getting distracted with other noise and you can still be able to hear it with a pretty clear sound quality.
You can use it on your mobile phones, laptops or any Bluetooth-enabled devices.
The Plantronics Voyager HD is a great headset to consider if you’re looking for a new headset. It has some convenient and enjoyable features that you might want to try out like audio streaming to listen to music through streaming or podcast and such. It also tells you of the device’s status like if you’re running out of power.Â
If you’re in a moving vehicle with the top down or with the window open, it even blocks the sound of the wind blowing to help your conversation stay clear and audible and you can even pair it with two gadgets simultaneously. Best of all, it’s compatible with most blackberry units, iPhones, android phones and other mobiles available in the market.
