larryiresto
30 points
Posted on - 05/02/2013
Hi there! Larry here.
I was working on a project involving after effects trying to incorporate match moving. However, I was suggested that mocha would be more applicable to what I am doing with my project right now. I am familiar with it but not quite and ready to look into it just in case. Now I was just trying to ask from you guys which one does much good with match moving type after effects mocha application software?
Thank you very much for a response.
What’s best use for match moving type: after effects or mocha?
Hi Larryiesto,
      You can try to check on Boujou 5 which is now available for OS X. It is the leading name for Match moving softwares. However, PFTrack is a more sophisticated software, it has more features like object tracking, tracking facial features it also supports API documented programming. But of course it comes with a price. Another one is CAMERATRACKER it can work with Adobe After Effects this comes in a cheaper price and almost same features as with Boujou and PFTrack.
