What’s difference between apk to fla and fla to apk?
I have a confusion  in understanding these two file formats. Can you please help me understand them and how i can accomplish apk to fla conversion.
Apk is android file format and fla is flash file format. To convert an android file to flash file you need a smart converter. The converter should be featured by both .apk and .fla supportive file format conversion. You can try this one http://www.fileguru.com/apps/apk_to_fla.
Best Regards
Hi Chet,
File extension APK is a file format created by google and is similar to EXE, MST and AIR. It is an android package file. It is able to run on an android mobile phone depending on its operating system. It can be opened on MAC OS, Linux and Windows while File extension FLA is a file format produced from Adobe Flash and is similar to BET, ALB and DFM. It is an Adobe Flash Animation. Adobe flash can create or produce animations or editable movies.
Speer Joanna
