What’s to expect from Samsung Smartphones new releases
Will the released of Galaxy S Advance (GT-I9070) and Galaxy Pocket (GT-S5300), removes the bugs that older Samsung smartphones have?
Hello Bessierromero,
Yes the Samsung Company has removed the bugs from the newest version that bugs were in the oldest version.
Actually authority got the customer response with only two stars because of the bugs and that’s why the company has removed the bugs to customize it.
You will get 4 inch display of super AMOLED. Also the device has been powered by 1GHz dual core processor so you will be able to use it as a computer in everywhere.
The mobile costs you Rs. 26,900 only. The company has explored another one that is named Samsung Galaxy Pocket and this is priced at Rs. 8150 so you can enjoy this one by expending only this amount.
Have a better device that will give you all features that you want.
Thanks
Newer models of mobile phones are sometimes the improvements of older versions it follows. But sometimes the release of a new version is entirely different from past versions. Bugs are mostly found in the operating system and not from the hardware or in the design of the handset. If a bug is found, the next version of the operating system surely contains the fix.
The Samsung I9070 Galaxy S Advance is also called Samsung Galaxy S II Lite. It supports 2G and 3G and fits in a mini-SIM. This model was unveiled in January 2012 and released around April the same year. It measures 123.2 x 63 x 9.7 millimeters and weighs around 120 grams. It has a super AMOLED capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution.
It supports multitouch with TouchWiz 4.0 UI, microSD can be expanded up to 32 GB, 3.5-millimeter jack, internal storage available in 8 and 16 GB running on 768 MB RAM with 2 GB ROM. It has Bluetooth 3.0 with HS and A2DP, NFC but optional, and microUSB 2.0. The primary camera supports 5 megapixels at 2592 x 1944 pixels resolution with LED flash and autofocus.
It features geo-tagging, face and smile detection, and touch focus. It can do video recording in 720p at 30 fps. The secondary camera supports 1.3 megapixels. It runs on Android 2.3.6 Gingerbread powered by NovaThor U8500 chipset with dual-core 1 GHz Cortex-A9 processor and Mali-400 GPU. The operating system can be upgraded up to 4.1.2 Jelly Bean.
For internet browsing, it supports HTML and Adobe Flash plus support for Java via Java MIDP emulator. It is powered by a removable Li-Ion 1500 mAh battery with standby time of up to 570 hours on 2G and 550 hours on 3G while talk time is up to 15 hours on 2G and 7 hours 20 minutes on 3G. It is available for around 170 Euros.
