Hello Techyv.com!
I was using MarsEdit 3 for quite a while already, it helps me a lot on my blog postings and article writings. Now there is this update MarsEdit 3.5, now I was wondering if it is way better than this version that I have been using. Is it more user friendly? What is new and better in this new version? Thank you techyv.com!
What’s new and better with MarsEdit 3.5 over MarsEdit 3?
Hello Larry,
You have been using MarsEdit 3 for a while now so you are pretty familiar with it. I personally never used it before, but I'd recommend downloading the newest update, try it out for a bit and compare the results for yourself. However I did find a website with some useful information on it you can visit it here. https://red-sweater.com/marsedit/ I really hop that helped you.
Thanks for reading.
– James C Montes
