Hi to every one. I am facing problem when with fifa 2013 for ipad2. Whenever I try to play fifa, my iPad shows error that there is no SIM CARD. I have to reboot on iPad to work properly and again same message if I play fifa. I don’t understand why SIM CARD error occurs. Is there any fault in my iPad or fifa game is not installed correctly? Please some help.
What’s problem while playing fifa 2013 for iPad2?
Hi reinstra,
"NO SIM CARD" issue on your iPad2 is a not a common problem but in your case should be your sim, as far as my few friends are using ipad2 and FIFA works well with it.
Or you can again download fifa 2013 and reinstall on your iPad
Thanks for asking
Problems with SIM Card recognition are not uncommon at all, however, this does not seem to be a known issue. It seems there is a software/hardware conflict with FIFA 2013.
The first step would be to substitute your SIM Card and if this wouldn’t work, soft reset and hard reset is not out of the question.
As a last resort you should report this to Apple as there doesn’t seem to be any upgrade, fix or way to solve, without individually verifying the device and/or the software installed.
