What is Samsung’s ‘safe taxi service’ application?
I heard about Samsung's 'safe taxi service' application.
How will it work for the safety of the passengers?
Will we need any extra device to use it?
Hello Greg,
If you rely on taxi services to get around more often, then you can admit that as good as the service can be there are cases where you have met a driver who is less courteous or outright scary. Samsung wants to save passengers from such situations and keep them safe.
It is doing this through a patent application that was just published for an end to end taxi service. It is fundamentally a taxi finder that has got a rating system. The mobile application in that patent has the ability to hail a cab that is close by depending on the kindness rating of the driver and as well verify if the vehicle the driver is using is the right one.
Once the passenger enters the cab, the Samsung implementation takes on a shape that is more distinct. In the event that the driver endangers the life of the passenger, a passenger enables SOS mode will flag the location of the car so as to get the police on the scene before the situation becomes worse.
Carl
The Samsung's Safe Taxi Service has the following two features that ensure passengers safety
The following images will illustrate how the emergency sos works;
Notifications
