I just downloaded and installed a Microsoft office 2007 with a Microsoft access in it. Â I heard from a friend about shift report in Microsoft access database, and now wondering what was that all about. Can anybody tell me what was that all about? Any videos and tutorials will be the best help you could give me.
What is a shift report in access database and how to use?
Hello joshephadamm,
Here I solution of your problem after thinking about it. Hope so it will help you.
Watch the video below
You will have to spend some time on it then it will be easy for you to understand the reports in MS Access.
Regard,
Harthy Opera
Hi Joshephadamm,
Several features have been introduced in Access, and some features in Access 2007 may no longer be functional in later versions of the software.
1. The user interface has changed, with a ribbon replacing toolbars and menus.
2. You can open and publish but not create old Access documents in newer versions of the software.
3. The Opening Access Data Project function has been discontinued and replaced with several other features.
Microsoft has dedicated a full page on new Access features.
Hope this helps.
Murakami Wyatt
