What Should Be Done When Excel Macros Not Working
Macros are quite necessary especially when we are working on repetitive information in Microsoft excel. But sometimes this handy tool may be found inactive or irresponsive what should be done when excel macros are not working?
Answered By 20 points N/A #177981
A series of commands is what a Macro is that you can use to automate a repetitive task, and can be rerun when you have to perform the task. There are certain hidden risks involved in the usage of macros and it’s over usage will lead to a situation where it will be stuck. If unaware a hacker can introduce a destructive macro in a file that can spread a virus on your computer. So first of all use it wisely.IN case you need to use it use only per requirement so that it won’t go “overload”. Referring Microsoft help centre on online customer service will also be helpful to solve the problem
