What skills should a good software engineer have?
I need to know the skills needed to become a good software engineer.
The skills needed to become a good software engineer is to some software development tools like java and C++ etc and some graphical tools like embedded, desktop, enterprise, web etc.
The main skills of a good computer engineers based on these
1. Read code or write code perfectly and accurately.
2. Design software with attraction.
3. Awareness of the Software Development Life Cycle.
4. Can use frequently library function and also fireworks and debugging.
5. Know use of Integrated Development Environments.
6. Ability on use of Version Control
7. Automated Unit Testing and Refactoring.
8. Have to be an expert on use of Build Automation.
Hi Quikee,
Being a Software engineer is the most in demand job in the world. Being in the computer age, a software engineer is really a good help to solve the issues regarding computer. Â
To become a software engineer you must of course love and know programming, must be knowledgeable in math (needed for design) can work as a group, never ending research, has a good contact also with the other software engineer to ask for their guidance, help and suggestions.
Hope this might help you.
Thanks
Hi Quikee,
A software engineer is the person who has  a great responsibility of any containing software a computer have. A lot of things should be considered in order for you to be a good software engineer.
1. Â A software engineer should know how to understand computer languages like Java, C++. Since these are the fundamental tools used by software engineer in delivering useful software.
2. A software engineer should be organized, disciplined and efficient with his work.Â
3. A software engineer should be respectful. Confidentiality of employers or clients irrespective of whether or not a formal confidentiality agreement has been signed is very much important as a software engineer, your credibility matters.
You know Quikee, it takes a lot of effort to be a good software engineer.Â
I hope I able to help
rhomz
It requires good frame of mind & through knowledge of applications to become a good software engineer. You should have your basic clear in your mind. You need to have practical knowledge of JAVA, .NET, ASP, Visual Basic, Oracle.
You can become good software engineer as the experience gain & as you work in more and more different types of project. Creativity must required for a software engineer. You should have good creation & project work knowledge. The practice in various projects will help you more. The combination of all of above will make you a expert software engineer.
This is the best solution.
