Hi to everyone,
What software you suggest on creating data tables design? I don’t have any idea on what kind of software to be installed in my computer that will possibly allow the user to make tables. I will have to encode contact name, date and address of a person.
Thank you.
“ARI Data Tables” is your solution, “ARI Data Tables” modules can easily converts “HTML” tables into very powerful and reliable tables in order to their types like pages and filter. It has the ability to make different charts all regards to your data from tables.
This “Powerful Extension” can load “SQL” and “CSV” database files too. Get this extension.
Hi Anthony!
You can use Microsoft Office Access. It is easy to use because you can also select the table and attributes needed when structuring a query. You don't have to type much of the query.
Another is MySQL Workbench. It is a database management system similar to Oracle DBMS. Unlike Access, you will have to type the whole query that you will run. You will need to install WAMP if you are going to use MYSQL.
