What softwares can i use for PDF editing?
You can use Adobe Acrobat Professional or Foxit phantom PDF editor.
Nitro and Adobe are good but what do you think is the best?
For PDF Editing tools I recommend Adobe Acrobat Pro. This is the best PDF editor that I have ever used because off course it is Adobe product. Even a scanned document that converted into PDF document can be edited because of its OCR feature.
For the free PDF Editing tools, OpenOffice.org Draw is one of the best. We have also the Inkscape where you can only edit a PDF document one page at a time then combine them after editing. PDFedit, combine, view and edit PDF external structure.
PDFTK, this is a command line tool for PDF. Aside from this software, you may found also other free software on the internet. Just search it on Google.
Notifications
