What is the solution when PC crashed on playing games?
Try using the on sign video if you are using a recording record.
Yes, I'm using a video cardboard. If I use the on game board recording and then the difficulty goes absent. How can I vindicate if the video carte has the job?
Also try using software inquirer same memtest86, occt, furmark. You can also stop for the peak declaration and oftenest of the display.
your os are not matched to your live
You should buy a new 3-d card that a you can play games that are advanced and use more memory. Also upgrade your display drivers and Direct x version.
Hi
It is better if you mention the performances of your machine. I think this problem happens not only for a one game but for all the games.
If it happens for only one game it can be the problem with the source that you have used to install the game.
Normally PC will crashes because of the problem with Ram or the VGA card. Most of the games install and start but cannot play the game.
It is better check the minimum requirements for the game and plays it if you can satisfy those requirements.
If you can try one of the games that crashed in another friends PC hand se the result.
Thanks
Does it always crash when you play a particular game?
If so, try uninstalling and reinstalling the game and see if that helps. Make sure you have all the drivers of all your computer's components updated, especially the video drivers as some games actually need to have certain graphics card capabilities to function and some of these would be available by having the graphics card drivers updated.
Also make sure your computer has adequate cooling.
The computer would heat up if it's running a resource hungry application, if your computer does not have enough means to cool itself, it will crash to prevent any further damage.
