What is source code for diary in php?
Which code do I need to use as the source code for diary in php? Where can I get it? I have been searching for long in the Internet but I have found nothing. Please help me to get that code!
I would suggest you to learn PHP and MYSQL. This is always a good idea because, say you want to modify it to your specifications, it would be easy to make changes.
You can check out PHP-Diary, it is a fast open source software that you can use to save entries in a database or a file. It has multiple browser compatibility and a good authentication system.
You can download it here- https://sourceforge.net/projects/php-diary/
Notifications
