What speakers justify the power of the Asus RoG Xonar Phoebus?
The Asus RoG Xonar Phoebus is said to be the best sound card in the market with a 600 ohm headphone amp but the drawbacks are supposedly that if you do not have a great set of speakers that it would not really matter if you have a great sound card. Can anyone recommend a brand of speakers that will give justice to the power of the Asus RoG Xonar Phoebus?
Best Answer by Aguilar Wulff
Answered By 0 points N/A #153388
Dear user,
Having a good sound card means you should have a good system of subwoofers. Otherwise you can’t get the quality out of your sound card, since you have asked for some good brands, here are some
1. Altec lansing Expressionist Ultra
2. Audioengine A5
3. Creative Inspire S2 Wireless
Personally i recommend Altec Lansing sound system.
Thank you.
Answered By 25 points N/A #153389
Hi Janis,
If price is not a problem for you, then the best set of speakers I would recommend is the Bowers & Wilkins MM-1 Active Multimedia speakers.
It has a compact design but it does not compromise on sound quality. Nautilus Drive Technology is employed for accurate sounds making the bass richer and higher notes shriller. The quality of the sound is consistent even at high-level volumes. This is the best set of hi-fi speakers for computers that an equally impressive soundcard such as the Asus RoG Xonar Phoebus can accommodate.
