What is startup program na in Windows7
Hello expert, There is a huge difference between windows XP and windows7 on startup programs. While today also I don’t know what is startup program na in windows7? Please can you explain me?
Hello
To see and change startup programs in windows 7 follow these steps:
Start -> Control Panel -> System and Security -> Administrative tools -> System configuration
Now you can see all startup programs and if you want, you can disable some of them, but be careful since you can disable system programs and you may experience system failure
Or you can go to: Start -> Run and type msconfig. You'll get same result as in previous steps.
