What is the System error?
Hello
Its a common question come from the long time computer user. Its hard to find someone who don't saw those error. Here some explanation for those term
1. System error : Its also known as system crash, kernel error, bug check. Systems errors are very broad. Each of the error can happen in hundred or thousands place at the same time. And its very difficult to find the location and fix. For why this problem often create much problem.Â
2. 32 dll error happens when you missing some dll file  in memory or registry problem. And its cause huge performance reduce on system.Â
3. Syntex error happens when you enter any information in computer that is unknown to it or it cannot recognize. Its a sequence of character which is language for compiling. Â
Hope you have you answer
DLL (Dynamic Link Library) are files that are used/called upon by one or more applications in your system at the same time.
These do not execute by themselves, however, these files contain commands and codes that are necessary for their respective dependent applications to function.
Should one of these files be corrupt/missing, the application or one or more of its functions may not be able to function/run/execute properly.
That said, there is no system32.dll file in any Windows system.
If you have a virus scanner or a malware scanner, it is best to run a full system scan in your machine. If the system32.dll file is in your machine, you most likely are infected with a form of the harnig trojan.
This is a serious security risk and you should have it fixed/cleaned/removed as soon as possible using your security software as this can potentially damage your files and/or compromise your personal information stored on the computer.
