What is tethering apps android.
Hi Mates,
What is tethering apps android. Have been hearing a lot of noise about this. Just though will ask you experts about this.
Regards
Shukla
Hi Mates,
Regards
Shukla
Tethering is a means of getting internet connection without a wifi. A cell phone data connection is use to provide network services to another device. It uses its 3G connection to send/receive data to another device, usually through a USB data connection. Most people use it as their daily internet connection though it wasn’t the fastest connection. Slow internet connections and even most DSL lines are faster than the 3G connection, hard on processor and in turn battery intensive. Battery doesn’t charge much while tethering.
The meaning of Tethering is to use internet on your computer or Laptop with the help of any Android phone. The internet connection works when you connect your Android et to any other device such as your personal computer or Laptop and the internet will run on other device by the request of the device which is attached to Android such as Laptop or computer. This is done mostly through a USB cable which is the basic source to connect two devices. It is he best way to use the internet without a WiFi to your computer or Laptop from your Android set which is really amazing technology.
Tethering is using your android phone like a wireless modem. You connect your android phone to a computer, then harness its 3G or 4G connection to surf the web on your PC. There are  android tethering apps such as; Froyo, Wireless tether for root and PDANet. Every plan has a bandwidth cap for data transfer. If you tether, make sure you know the limitations and stay within them.
