Toby Malone
40 points
Posted on - 05/02/2013
I am planning to install a theme for my template WordPress friends that is organized properly according to our interest as young ones.
What will be the appropriate version of theme for us?
What theme is appropriate for my template WordPress friends
Hello Toby,
Put in mind beside the age, the content the web site will serve but in all cases.
I think you must go for the bolder colors like red and designs like Multimedia, celebrity themes, Buddy themes or any other easy access , two columns and very sharp colored.
Look at these designs and you will get what i mean.
Flix Buddy Press Ready,
Razon Cutting Edge WordPress
Hello Toby Malone,
If you want to get a best theme then i am giving you a website from there you can get the most best themes from there.
All you need is to check these ones. There are 80 themes and i hope that all will attract you as they are the best 80 ones.
And you can also get the procedure that how you can install and you can use them in your WordPress software.
