kurt andrew
10 points
Posted on - 09/10/2012
What is this feature in microsoft office 2010 that includes thesaurus and how it works? I am asking about more in microsoft packages so that I will be able to know all features that the microsoft office have. Can you give me some suggestions?
What is this thesaurus office 2010?
Thesaurus is a feature in microsoft office that helps find the meaning of a word.
You get it on the review tab under proofing category or by highlighting the word you want meaning of and right clicking to pick theasaurus.
A list of meanings will be displayed on the window.
Shift +Â F7Â should also give you the same. Some third party add-ins however steal control of Shift + F7 in which case fn + Shift + F7 works.
To disable the add-ins:
1) Click File menu, go to Options > Add-in, click Go button in the Manage: Com-in Add.
2) Check if there is any add-in; and clear the checkbox to disable it
