What is a third-party extension?
I just want to ask when I cannot connect on the net, because my browser says: "A third-party extension has blocked access to this webpage."What is third-party extension?
Third-party extensions on Internet Explorer are also called plug-ins that incorporates with the browser and used to improve your browsing experience. Normally, this worked as a toolbar with search functions, pop-up blocker, auto-fill form, and more. Some popular third-party extensions are Google and Yahoo toolbar.
This can block illegal sites and stop you from gathering information or any materials from that site. And you need to remember that, if you have many plug-ins installed on your browser, it might affect its performance. So, in order to disable those plug-ins, follow the steps below:
1. Click Tools> Internet Options> Advanced Tab.
2. Untick the Enable third-party browser extensions under Browsing.
3. Restart your PC.
A third party extensions or third party browser extensions are little pieces of software and programs that modify the browser to add any programs which are useful,entertaining or just plain random features for your original browser.
For example if your browser doesn't allow you to play interactive games on website, you might be able to play it by just using the third party extensions.
And with this useful things that add on your original browser you will be able to do the applications you need for your computer. By the way you can enable your third party extension by adjusting your original browser settings on advance tab just put a check on the box saying "enable third party browser extensions", you can always modify it when ever you like.
