What To Do If 2nd Hard Drive Not Showing Up In File Explorer?
What to do if 2nd hard drive not showing up? I cannot see it listed in Disk Management. Please help. I have a Windows 10 laptop.
These methods can help you fix the “2nd hard drive not showing up in File Explorer” problem.
Method 1
a. Press Windows + R.
b. Type devmgmt.msc and press enter.
c. Expand Disk Drives.
d. Locate your disk, right-click on it.
e. Update Driver Software.
f. Use the Internet to update the driver.
g. Complete the process.
h. Restart your device.
Method 2
a. Follow the steps in Method one to Uninstall the driver instead of updating it.
b. Shut down your laptop.
c. Reconnect the disk.
d. Start your PC, and check.
Method 3
b. Type cmd and press ctrl + shift + enter.
c. Type chkdsk g: /f and press enter.
d. Restart your device after the process completes.
